I recently purchased two propellers from the estate of a friend who passed away last year. These were purchased in Springfield, Massachusetts. One of these is just under three feet long, and can be seen in the attached photographs. There is a note that was wrapped around the prop that reads, "Prop for 1910 Weiss engine - made in CT". The numbers that are on this prop can be seen in the second photograph. It looks like they read "ND44" and below this is "J5115". The propeller appears to be in pristine condition. Do any of the members of this forum know what airplane it might have been used on?
The second propeller appears in the other photographs. It is just under seven feet in length, and really looks like it's in very good shape too, but not as pristine as the other prop. The hub has 8 mounting holes, and is tapered in shape. The front side of the hub measures about 10.5" in diameter, and the backside about 15.375" diameter. There are some markings on the prop, but they are difficult to read. In the attached photograph where the markings are indicated it reads "102-64", and there are some other markings below this that are difficult to make out. There are also some markings on the back side of the hub, but they too are difficult to read. I can post some additional photographs that show these markings if anyone thinks that it will help. I also have the mounting bracket that was used to attach this propeller to the airplane. But it doesn't have any markings on it that I could see. Do any of you know what airplane this prop may have been used on? Any help would be appreciated. Thanks.
Maui
Maui
