Old 06-17-2008, 09:08 PM   #1
ALE777
Default WOOD PROPELLER HUB: HOW DETERMINATE THE DIAMETER/ THICKNESS?
I am designing a wood propeller for a old engine, the GNOME 80HP, but I searched in lot of books about how to determinate the diameter and the thckness of the propeller's HUB, but had no results. WHERE I can find information about this? are there a standard values for these parameters? It will help me see various models of similar wood propellers? thanks!
Old 06-18-2008, 08:03 AM   #2
This chart has dimensions for the Gnome 100 and 160 hp engines, but I don't know if the 80 hp used the same hub.
I'll try to check on some other listings and if I have a Gnome 80 hp propeller, I can just measure the hub on that one.
Old 06-19-2008, 03:47 PM   #3
ALE777
Default THANKS!
Dear Dave:
Your chart is very usefull, was a good idea to put this in the forum, because it will be usefull for another ancient propellers builders, not only for me, I think. Thanks!!!
