Old 06-24-2019, 04:35 PM   #1
WBVulture
Default Help with ID of propeller and aircraft
The propeller is a Sensenich with the "SB" decal serial number 8743 and the model designation DES69D. It is for a 40hp engine at 2575 RPM. There are six hub attachment points.
I assume this is for the Continental 40 hp engine. How can I date the manufacture and determine which aircraft it was for (Piper E2, J2, J3, Aeronca series, Taylorcraft etc). Thanks!
WBVulture is offline   Reply With Quote
Old 06-24-2019, 04:44 PM   #2
Per Sensenich themselves you can't date it except that it was manufactured between 1932 and 1942.
When a propeller design was approved for several different models there is no way to tell which model might have used it, unless by some quirk you found a log entry for an aircraft that happened to match the exact serial number, which is extremely unlikely.
Old 06-25-2019, 01:05 PM   #3
WBVulture
Thanks for the info
