Old 05-26-2019, 01:35 AM   #1
tahoeheidi
Post Can anyone explain the insignia on this Jenny propeller
Looking for assistance/guidance identifying serial number D5000 16263 or anchor with US insignia. Thank you. Propeller Purportedly from a Jenny plane, 1920s.
tahoeheidi is offline   Reply With Quote
Old 05-26-2019, 07:43 AM   #2
The first image may represent a Paragon propeller. (The "P" was assigned to the American Propeller Manufacturing Company, which produced Paragon props.)
The numbers below it indicate the diameter and pitch of the prop. So it should be 8 feet in length and (in a mathematical sense only) should move forward 5 feet 3 inches per revolution.
I'm just a bit skeptical that it's definitely from a Jenny because of the U.S. Navy stamping, but it is the correct size for one.
I don't know about the bottom photo numbers. Can you post a picture of the whole prop?
Old 05-26-2019, 04:19 PM   #3
tahoeheidi
THANK you so much for answering. I've uploaded a pix of the WHOLE prop limited to 97.7 KB.
Old 05-26-2019, 09:02 PM   #4
It's hard to tell from that angle, but you need to measure the distance from the center of one bolt hole to the center of the bolt hole furthest away from it. That's the bolt circle diameter, and it can eliminate one or more engine types from the possibilities.
Old 05-30-2019, 03:35 PM   #5
tahoeheidi
Default Update on measurements
Prop has a 2" shaft with 47" out from there, so 96" total span. Will this work?
Old 05-30-2019, 05:54 PM   #6
You still need to find the bolt hole circle diameter. It's a critical diameter since it can rule out certain engines. I'm just guessing though that it fits either an OX5 engine or a Hall-Scott A2A engine, but those will have different hubs.
Old 06-07-2019, 12:52 AM   #7
tahoeheidi
Default Bolt Hole Circle diameter
Does this work Dbahnson for you to better identify the propeller?
Bolt Hole circle diameter
6 inch plate 8 bolts 2 in part
Thanks. Heidi
Old 06-07-2019, 12:57 AM   #8
No, your measurements are confusing. See this link.
Old 06-07-2019, 01:00 AM   #9
tahoeheidi
Ok. Back to the prop for better dimensions. Thanks for sending me the link.
Heidi
Old 06-07-2019, 01:25 AM   #10
tahoeheidi
Does this work?
So it's 6" plate from edge to edge. Here's a photo.
There are 8 bolts positioned at 2" apart from each other. Spans are 5-1/8" away from the far bolt dead center making them about 3/4" from the edge of the plate.
Photo attached.
anchor insignia
