Old 03-06-2018, 08:32 AM   #1
Neila
Default Vintage propeller identification
Hi AS a newbie to the forum I need a little help and hope this is the right place. I have purchased 2 props recently and need some help identifying them :
I will add details of the second prop later but the first I believe could be an SE5 prop ?
See pics added
Any help appreciated
Neila is offline   Reply With Quote
Old 03-06-2018, 11:09 AM   #2
gchuba
Newbie myself who just identified a propeller. Getting measured dimensions a big help identifying. Look at the "propeller identification early propeller section" and get the hub dimensions. Then length. Helps the more seasoned members/fellows out quite a bit.
gchuba is offline   Reply With Quote
Old 03-06-2018, 12:41 PM   #3
The "DG 2386" presumably is the "Drawing Number" of 2386, which is usually the way the prop is identified, but I can't seem to find reference to that number in my sources. Bob Gardner or Pierre-Michel might have some other source that would help.
What's on the other side of the hub? The information seems scant by comparison to most similar props.
Old 03-06-2018, 01:14 PM   #4
It's clearly a Chauvière made in England. With a very well preserved decal: take care of it!
Chauvière serial numbers were different in England and France. I think Bob will be delighted to see this prop because, IMHO, this serial (2386) is not in his book... So, as gchuba wrote, length, hub thickness, size of the central hole and diameter of the bolt holes circle will be very useful.
From the general shape, it is a "late" production (1918-1921).
Pierre-Michel
Old 03-09-2018, 06:39 AM   #5
Neila
Thanks Guys
length 410cm
hole centre to hole centre 14.5cm
centre hub hole diam 6.7cm
Hub diam approx 19.9cm
hub depth 13.3cm
hope this helps
Old 03-09-2018, 07:18 AM   #6
Originally Posted by Neila View Post
Thanks Guys
length 410cm
hub depth 13.3cm
hope this helps
410cm= 13ft 5.417323in
That doesn't seem at all consistent with the photo. Did you mean 310 cm?
Old 03-09-2018, 07:33 AM   #7
Neila
Ah yes
Let me check
Old 03-11-2018, 05:25 PM   #8
Neila
Length 240cm
Old 03-11-2018, 06:17 PM   #9
That makes more sense.
Old 03-14-2018, 11:39 AM   #10
Neila
Hi
have the dimensions helped at all for anyone to help me identify ?
