Old 02-28-2018, 06:29 AM   #1
Default Beech prop
I received pictures of an automatic variable pitch propeller with apparently wooden shielded blades. Any info welcome ! Diameter about 2.24 meters (~88").
Best regards,
Pierre-Michel
EDIT: The pictures are so good I forgot to copy what the owner wrote about the markings:
Voici les inscriptions de sa plaque signalétique :
HUB ASSEM B200 -100 (354)
SERIAL 4-108 T.C 067 P.C 5O ou 5C
BEECH AIRCRAFT CORP WICHITA KANSAS
Old 02-28-2018, 07:55 AM   #2
I think the expert on these newer variable pitch props is Monte Chase. I think he can be contacted via his web site, www.notplanejane.com.
He has a huge collection of them and knows a lot about the topic.
Old 03-02-2018, 02:43 PM   #3
Yes! Fine idea! Monte Chase told me the prop has been used on B-35 Bonanza and some others Beech types: B35A, C35, D35, E35, 35R, 45 (= military YT-34), et 50 (military L-23A) with engine up to 250 HP.
I was wrong to write about an automatic variable pitch propeller in my post: it was electrically manually controllable from the cockpit.
More recent type of "Bonanza" (B-36) uses a three baded prop.
A 1947 advertisement for the first Model 35 Bonanza in 1947 shows a variable pitch propeller with same shielded blades:https://en.wikipedia.org/wiki/File:A..._May,_1947.jpg
Best regards, and thanks again for the guidance!
Pierre-Michel
