Old 07-22-2017, 08:55 AM   #1
illenberger
Default German WWI propeller No.2
Dear folks,
since my first posting a while ago, I got a second German prop which is in excellent condition, and which carries metal plating on the tips and almost half length of the leading edge.
From what I can see the data of the prop is as follows:
Manufacturer: Wolff, Berlin
Serial No. 3054
Engine Type: MERCEDES, 260HP
Pitch: 178
Diameter (not measured but taken from the hub imprint): 315cm
6 bolts
Can someone kindly give me a hint on which a/c type this prop might have been installed?
Thanks in advance for your help!
Joachim
illenberger is offline   Reply With Quote
Old 07-22-2017, 09:35 AM   #2
illenberger
Default One more thing...
Having done a bit of research before, the prop must come from one of the larger aircraft from that time given the engine power rating of 260HP.
From what I understand, the AEG G.V is the most promising candidate.
I found the following photo on the web:
http://www.airwar.ru/image/idop/bww1/aegg5/aegg5-4.jpg
On this photo, there seem to be even the metal protections on the leading edges:
http://www.kheichhorn.de/assets/imag..._GI_bis_GV.jpg
Old 11-19-2017, 03:54 PM   #3
Props of this size made by this maker were fitted to Rumpler CV aircraft. Wolff props for the AEG G IV had a much smaller Steigung of 1500mm.
