Old 03-26-2014, 07:41 AM   #1
nl77621
Default Help to identify propeller
Hi everyone, I have a 4 blade propeller that has the following identification numbers on it
DRG CD 40597A
SER NO 4668
It also has a small round logo with circle and inside circle A73
Can anyone give me more information on this propeller?
Thanks for your help!
nl77621 is offline   Reply With Quote
Old 03-26-2014, 07:53 PM   #2
It's certainly an unusually high drawing number, especially if it's WW1 era. I certainly don't recognize it offhand. Do you have a full picture of the prop?
Old 03-28-2014, 08:54 AM   #3
nl77621
Hi Dave, thanks very much for your help! I've posted some more pictures let me know what you think.
Thanks again
Old 03-28-2014, 09:24 AM   #4
How long is it from tip to tip? I think that's an auxiliary prop of some kind, usually for generating electric power. The 4 hole hub virtually eliminates its use on standard aircraft engines.
Bob Gardner may be able to refine it futher. He drops in here from time to time.
Old 05-19-2014, 08:33 AM   #5
wallpaperman
Default wallpaperman
hello,
I am from Finland and bought this Astra propeller from Estonia at 1992.
8095
PS 185 B
D 305
S 172
Lenght is 305 cm
Blade wide is 29 cm
hub is 23 cm
hub hole is 8,7 cm
4 boltholes
Matti Parkkila, Wallpaperman
wallpaperman is offline   Reply With Quote
Old 05-19-2014, 01:07 PM   #6
Hello Finland!
Astra props are comparatively rare. The serial number of yours, 8095, is the latest I have recorded which suggests your prop was made in the latter half of 1918. Two Astra props are recorded for the NAG 185ps engine powered DFW CV, although they had a diameter of 2950mm and a pitch of 1850mm compared with yours of 3050mm and 1720mm respectively, so you should regard this attribution as possible rather than probable.
