Old 08-19-2006, 05:16 PM   #1
chall
Default Wooden Prop Plans
My 16-year-old son wants to make a 72" wooden propeller to enter in a woodworking contest, and later display in his room. We understand the basic process of laminating a stack of 3/4" rough-cut wooden blanks, making a metal hub, then doing all the carving/polishing/finishing work. What we haven't been able to find is a set of templates for the blanks. If anyone knows of a source for that, we'd appreciate it. Thanks.
Old 08-20-2006, 11:29 AM   #2
You could use this one, and I have some drawings of a SPAD propeller that might work as well.
Old 08-20-2006, 09:48 PM   #3
chall
Yes, we'd been looking at the blueprint at http://www.woodenpropeller.com/blueprint.jpg. We figured we could just scale it to the size we want. I can sort of guess what the shape would be on the finished propeller, but what we've seen and like a lot is the Sopwith Pup propeller (funny, since that's the one in your signature).
Do you have the SPAD prop plans in electronic form, or just hardcopy? I'd be curious to see them, but don't want to put you to any trouble.
Thanks.
Old 08-21-2006, 12:21 PM   #4
It's just hardcopy, and it's bigger than will fit on my scanner, so I need to scan it at work and reduce the size. This is part of it, but shows basically what it looks like.
Old 08-23-2006, 10:35 AM   #5
ec121connie
Hi Dave,
I would be very interested in the scans of the prop plan as well.
I was asked to volunteer, at the local aviation museum, to make two display props. I have carved smaller examples in the past but would like to make sure I'm on the right track. With the cost of hard wood being what it is I can't afford to make an error.
I would be more than happy to convert / re-draw the plan in corel, DXF or PDF format and post it back if that would help
Here is a link to the museum page
Bill
Old 08-23-2006, 01:41 PM   #6
I'll be back at my house in a few days and get to work on scanning it and then either emailing or regular mailing it to you. There are quite a few requests for this kind of drawing and not much available anywhere I've found, so it would be worthwhile getting something published on the web.
Old 08-23-2006, 11:21 PM   #7
rsloop
Chall,
I have a file of SPAD propeller photos if that helps your project. Let me know where to send them
RSloop
rsloop@gmail.com
Old 09-11-2006, 11:05 AM   #8
ec121connie
Default Prop Plans
Hi Dave,
I have the four footer, for the museum, about half done. I'm just winging it but the shape and twist appear to be visually correct. Since this prop is for display only I just have to get it close.
Any progress with the scans yet? I'll draw the plans in vector format as soon as I get a look at your scans. Usable templates might be a help to the folks.
Bill
Old 09-11-2006, 12:58 PM   #9
I tried to copy them on our office copier but I think they are too long for the copier. I might just try to photograph them on a copy stand and send you the images.
Old 10-05-2006, 09:33 AM   #10
ec121connie
Hi Dave,
I was able to carve the prop for the museum display using a profile drawing that I sketched and a lot of time with hand planes and a rasp. Actually came out rather nice.
Here is a link to a photo
http://www.woodcentral.com/content/v.../pic291581.jpg
If that one doesn't work here is a backup.
http://www.woodcentral.com/cgi-bin/m...pl?read=291581
If you ever get the copies of the plans let me know. I'll re-draw them.
Bill
