Old 09-30-2019, 07:12 AM   #1
jasong
Default Propeller ID: 3.7m diameter 4-blader
Hi Everyone,
I'm trying to identify possible aircraft for a cut-down four-blader that has been sanded and revarnished (not by me) which make the hub stampings very difficult to read, but appear as follows:
AD 555
LEFT HAND
75HP RENAULT
D3744 P2680
The 75HP Renault does not appear to have been a widely-used engine, with scarce references mostly focussed on 70HP and 80HP Renault engines.
At 3.744 metres, it would have been a very impressive prop. Such a shame it's been cut down.
Any thoughts? I've attached a photo of the hub stampings. Unfortunately I don't have anything else to go on.
Cheers,
Jason
Jason Gehrke, Brisbane, Australia
jasong is offline   Reply With Quote
Old 10-01-2019, 06:18 AM   #2
"AD555" was a two bladed prop used for a Clerget engine, so that doesn't fit. I can't really read the stamped numbers. There is a listing for "AD 532" which is a left hand tractor 4-blade with a Renault 75HP engine for the BE2c. At this point I'm guessing that's the most likely match, although I don't have the data for the diameter and pitch on that model to see if it matches yours.
Stamped horsepower often doesn't match exactly what is now listed as horsepower for a specific engine.
Old 10-01-2019, 10:40 AM   #3
Hello Jason,
Good to hear from you again!
Another possible interpretation of the remains of the markings on your hub is:
AD535
D2744
P2600
These data are for a Standard Prop (ie; authorised by the Air Board) for a 75hp Renault engine for the early BE2C.
AD indicates that it was originally a design of the Air Department of the RNAS, but still extant in the 1918 list of Air Board numbers that I have.
Old 10-01-2019, 11:16 AM   #4
jasong
Thanks Dave and Bob. Hope you're both well.
You could be right about it being 2.744m rather than 3.744m Bob, in which case a BE2c is a perfect fit. A four-blader that big would be extraordinary. It's just so difficult to read the stampings.
I really appreciate your insights and expertise.
Cheers,
Jason
Old 10-01-2019, 01:15 PM   #5
I'm delighted to be of help, particularly to an Australian, and even to an American!
Old 10-01-2019, 01:20 PM   #6
Jason,
Remind me, for I grow ever more slow of brain. Did I send you a complete set of my books recently?
Were they up to scratch?
Old 10-01-2019, 03:05 PM   #7
AD535
D2744
P2600
Bob, do you mean AD 532? I have that listed as a 4-blade LHT for a Renault, but I have AD 535 listed for a Fiat engine.
Old 10-02-2019, 05:20 AM   #8
Greetings Dave,
Confusingly there are two entries for AD532 in the Air Board list of 1918 that I use.
Firstly, AD532 for a 75hp Renault for the BE2C aircraft. This is not listed as a Standard Prop
Secondly, AD532 is also listed for a 250hp FIAT fitted to the front nacelle of a R23 RN Airship.
Neither listing shows any dimensions, nor are they listed as Standard props. I assume this is a clerical error by an Air Board clerk, who may perhaps have been day-dreaming about his girl friend etc.
The drg number AD535 is much more convincing.
Old 10-02-2019, 08:02 AM   #9
jasong
Nothing wrong with your memory.
Yes, I did buy a set of books from you recently - I think I now have all of your propellor books. They are a great reference.
Cheers,
Jason
Old 10-02-2019, 10:54 AM   #10
Thanks Jason,
Now that you have the reference books we can enrol you as a forum expert!
