red tip wood laminated propeller 44"
  • red tip wood laminated propeller 44"
    Trying to identify year, manufacturer, if authentic vintage, etc.
    for the following design numbers stamped around outside of propeller center opening
    876
    17
    AY702
    I didn't see how to post photos but can email to you, Thanks for your help
    Did you try the "Manage Attachments" link below? That should work unless the photo files are huge.
    You can get to that link by either editing your existing post or replying to this one.
    Photos are probably essential, as I don't recognize any of the numbers. How long is the prop from tip to tip?
      I've attached your photos here and deleted them from the "Early" propeller category.
      It's almost certainly a drone prop from the 1940s or 1950s, and most likely a target drone, similar to this one.
      A number of these have appeared on eBay, generally selling for a few hundred dollars or less. Many of them had been purchased from various surplus shops in the 50s and 60s, as they had been manufactured in fairly large numbers before becoming obsolete.
