#1 |
Hi guys. I was hoping that somebody might help me ID a propeller I recently acquired?
It is a dark wooden prop, brass on leading edges all the way to the tips. Fairly pointed, sharp tips with 8 mounting holes in the hub. Prop is about 2,3m long. Markings visible around the hub are: Mongoose D2210 P1665 DFC 2 Markings to left of hub: WATTS 908/2 Markings to right of hub: AG 28515. Of interest is a wooden ring all around the hub which seems to have been used to mount a spinner, based on the holes visible on it and the tapering lines/grooves from in onto the hub itself. I would really appreciate it if somebody might be able to give any indication as to what aircraft this could have come from. Thanks so much. |
#2 |
Your propeller is from a Hawker Tomtit, powered by an Armstrong Siddeley Mongoose engine.
That’s a nice prop and quite a rare item, only 35 of the type having been built. https://en.m.wikipedia.org/wiki/Arms...deley_Mongoose |
#3 |
Since this is a post WW1 prop I've moved the thread to the "Modern" category.
#4 |
Great. Thank you very much for your reply. Much appreciated.
#5 |
I see according to Wikipedia that 4 aircraft were sent to New Zealand at some point. The previous owner lived in New Zealand so Im guessing it would most probably have come from one of those aircraft!?
#6 | |
![]() Quote:
You probably know this already; it’s been said many times before on this forum but it is worth repeating: Please don’t be tempted to do anything to “improve” that beautiful propeller except gently cleaning and treating it with beeswax. |
#7 |
Yes. Thank you for that. I dont plan on doing anything other than the cleaning as suggested. I did email the Shuttleworth collection who operate the only remaining Tomtit and they have confirmed that it is indeed a Hawker Tomtit propeller. Thank you very much for all the assistance and advice.
Thread Tools | |
Display Modes | |
