Old 07-21-2019, 07:09 PM   #1
GRB
Exclamation Had since I was 16(60 now)
I have a 94.25 inch wooden prop it has Fahlin D600 NO 25797 H.P. 125, RPM .2050, AIC 606. Any info would be appreciated. Per the listing a D600 should be 100 HP not 125. I'm just trying to get closer to what plane it would have been on.
GRB is offline   Reply With Quote
Old 07-21-2019, 09:11 PM   #2
It's probably a D600A, since it's stamped for 125 HP, and would have been fitted to one of the aircraft on this list. There's no way to know which one of those based on the information you have.
Old 07-21-2019, 10:16 PM   #3
GRB
Thanks for the reply Dbahnson. That's what had me confused because there is no sign of an A. I was looking so I could mount it a little nicer too see maybe what the front might have looked like on the plane. I've drug this thing around for a lot of years and it's time to try and do it right.
Old 07-21-2019, 10:33 PM   #4
Next week when I'm home I'll see if I can find anything more about its type certificate. The "AIC 606" is more likely ATC 606 which is the "Aircraft Type Certificate" that specifies certain parameters of the propeller.
