Old 06-04-2018, 12:38 AM   #11
dairwin
Originally Posted by n99jh View Post
Hi Dairwin
Thank you so very much for your help. The 330 cm diameter converts well to an approximately 10' 6" diameter propeller, however, I doubt that the other number is the pitch, that would mean 11' pitch !?
The Hurricane Watts propeller has a 11.25' diameter and pitch of 21.3' (see photo). So don't dismiss the pitch; these are very pitchy propellers optimised for high speed only.
DAI
dairwin is offline   Reply With Quote
Old 06-07-2018, 07:26 AM   #12
n99jh
DAI
I have done some more research and found that the Hawker Hector which used the same Napier Dagger engine as used on the MB.2 had a Watts Z.3040 propeller, 10.9' dia. and 12.15' pitch. This may very well be the same propeller as the one loaned to Sir James Martin.
You are correct about the pitch!
n99jh is offline   Reply With Quote
Old 06-07-2018, 07:44 AM   #13
dairwin
For the Z.38 Hurricane propeller, the Rolls-Merlin II could only develop approx 2,100rpm at take off. The equivalent Watts used on the early Spitfire Mk1 had a take off length of 450 years, but when changed to the two-position deHavilland propeller the take off run reduced to 230 yards as that propeller was optimised with fine pitch.
The photo is my Merlin II with a Z.38 propeller. The pitch is evident!
DAI
Old 06-26-2018, 09:12 AM   #14
dairwin
I am back at it
Would really appreciate any information regarding the pitch of this propeller.
Joshua
Joshua,
Came across another photo of a Watts for a Kestrel V.
DAI
Old 06-26-2018, 07:19 PM   #15
n99jh
Joshua,
DAI
Thank you very much, your help is much appreciated.
