Go Back   Wooden Propeller Forum > Welcome to the Wooden Propeller Forum > New to the Forum? Start Here.
Old 11-05-2008, 02:33 PM   #1
Default Posting Photos on the Forum
There are two ways to post photos here, depending on whether the photo is (1)on your computer or is (2) hosted on a server on the internet.
1. If the photo is on your computer use the attachment option at the bottom of the "Post Reply" to upload the photo from your computer to the forum database and display it. The viewer then clicks the thumbnail to see the full photo. Make sure you reduce and compress the photo size first, especially if you are using a several megapixel digital camera. The maximum size of a photo is currently 100kb and 1024 pixels x 768 pixels, which means you need to size the image to a maximum of 1024 pixels on width and 768 pixels on height. See below.
2. If the photo is already on the internet, copy the URL, click the icon at the top of the message window and paste the URL into the box.
In most cases where you use your own photos, it is best to first reduce the photo file size. There are many photo editing options that can reduce photo size, including Irfanview ( an excellent free program), Photoshop, and many others. Cropping the photo first to just show the relevant component (usually just the propeller itself, with little or no background) is generally the first step. Then the file size can be reduced and the photo can be compressed using the photo editor. A 1 MB file size can show adequate detail even though it's been reduced to under 100 KB.
(In the near future I will be adding detailed instructions and examples of this process. In the meantime this tutorial, which was written for the old forum, might help you get started.)
Dave is offline
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
