I was given a wood propeller several years ago and was glad to find this forum. My interest was renewed after seeing WWI replicas flying recently.
Any ID help is appreciated.
Photos attached.
Due to damage around the hub, the only marking that remain are:
Back side: "1" at root of one of the blades
Back side: "2" at root of the other blade
Front side: "V" (could be an "A" but seems to be missing the cross bas)
Specs:
4 layers
6 bolt holes
Each bolt hole is slightly more than 1/4 inch in diameter
Each bolt hole is 4 1/4 inches diagonally from the opposite bolt hole
Bore: 2 1/4 inches
Bore depth: 3 3/8 inches
Length: 6 feet
Color: likely light colored originally but now stained dark
Leading edges are metal clad with completely clad tips
Shape is symmetric
Thanks much!
Photos attached.
Specs:
4 layers
6 bolt holes
Bore: 2 1/4 inches
Length: 6 feet
Shape is symmetric
Thanks much!
