Asking the experts...
I was given an "old" wood propeller, well actually the center hub section only.
I was told that is was from a military aircraft that crashed, possibly WW1. The propeller was cut to remove the damaged portions and create a keepsake.
The following marks are all that is on it;
SER. A 24248 E
MOD. 72 F 49
The Specifications (please excuse my ignorance in terminology):
...laminated wood construction
...27 layers in total, the first layer is much thinner that the rest
...6 bolt holes
...each bolt hole is 1/2 inch in diameter
...each bolt hole is 4 inches diagonally from the opposite bolt hole
...the internal hub (hole) is 2 1/4 inches diameter
...the internal hub (hole) is 3 1/4 inches in depth
...the external size of the hub is 6 1/8 inches in diameter
I know nothing about this propeller. Any information would be greatly appreciated.
Cheers,
Brad
SER. A 24248 E
MOD. 72 F 49
...6 bolt holes
Cheers,
Brad
