Confused!!!
  • Confused!!!
    THIS PROP I HAVE HAS GARDNER STAMP-BUT NUMBERS DON'T SEEM TO MATCH UP-CAN ANYONE HELP ME SOLVE THIS MYSTERY???I'VE BEEN AT IT FOR HOURS!
    PT-17 AIRPLANE
    R-670-5-ENGINE
    220 H.P. AT 2075 RPM
    PART NO. 42K19593
    NPRS SER NO 43282
    IT'S ABOUT 8FT OR SO-CHERRY COLORED WOOD-GARDNER STAMP, but no matching part nos. I'm lost- I think I want to sell it, but I'm not sure and I want to learn more about it first.
    WEll it's a little convoluted, but I have a listing of a Sensenich drawing number 42K19593 that corresponds to Type Certificate 546.
    TC 546 is also designated for 43K19181 and you'll find that listing here, which shows it was a military contract for the civilian model 90-LA 76. That exact model isn't specifically listed on this list, but that list does show a 90-LA model with a different pitch, using the Continental R-670 5 engine, the same as yours. The horsepower is correct for that as well. I presume that Gardner simply manufactured it under an agreement with Sensenich, who held the type certificate for it. That practice was not uncommon.
    It is clearly stamped for a PT 17 Airplane, however, and the other data fits even though we don't have it listed. It would have been made under a 1942 military contract and used on the PT 17 (Boeing Stearman).
      I'll add the new drawing number to the web page. Thanks Dave!
        prop
        what is the over-all lenght of your prop?
          Length
          It's about 8-9ft long
            Value???
            By the way how much is this worth-is this something I should be donating to a museum-selling, I love it, but we are so broke right now; I'm extremely conflicted as to rather or not I should hang on to it. Also is there any way to track what plane(s) it was on?
              It's almost impossible to know what specific plane it went on, and I think you'll be disappointed with a museum's response to donating it to them. It's not particularly rare.
              The "market" for selling any collectible right now isn't very good. My advice is to just hang on to it. If you want to sell it, eBay is still your best bet. You'll need good photographs and a good description. I'd put a reserve on it. Use whatever value you want, but if it's higher than around $750 you might discourage any bidding.
                prop
                i would think about buying it but i would have to know in inches how long it is .
                  It's 90 inches long. The drawing number (90 LA - 76) shows that the diameter, or length, is 90 inches and the pitch is 76 inches. It doesn't hurt to have the owner actually measure it as well, though, because if it's less than that it means the tips have been cut down.
                    Measurements
                    i am moving so my tape measure is lost-but as soon as i find it i will post exact measurements/thanks dave.
                      Measurements
                      My husband measured it and says it's 98" long.
                        ALso
                        It has not been trimmed anywhere-the shiny parts are all still there-it's actually (now that we've cleaned it) in remarkably good condition-we're impressed with it. Some of the numbers are a little worn from age-but still okay-it's very nice.
                          According to the specifications for the design number, it's 90 inches in diameter (90 inches long). If in fact it is 98 inches in diameter then the design number is wrong. I know of no exceptions.
                            huh...
                            okay-I'll ask my husband to measure it again-maybe he's measuring it wrong, what is the best method for getting an accurate measurement???. thanks for the info!!!
                            Last edited by pollygirl; 07-25-2009, 10:01 PM. Reason: advice needed on mearsuring
                              Get a 10 ft tape measure. Have him hold one end against the very tip of one blade and pull the tape tight across the entire blade. Read the number on the tape that's just over the tip of the of the opposite blade. If it says 90" or 8" ft 4" where the prop seems to end, that's the length.
                              Don't let your husband do it. I think he screwed up once already.
