Identifying MAY 1943 Prop
  • Identifying MAY 1943 Prop
    Can anyone PLEASE help me identify who manufactured this Wooden Prop?? Secondly, what type of plane used this prop? The serial numbers that I can make out on the hub are:
    SS-220-D
    RANGER 6.440.C5
    W2369
    MAY 1943
    By the bottom line, I am assuming that it was made in May 1943. The prop actually has new stickers on it saying:
    Hamilton Standard
    Winsor Locks Connecticut
    United Aircraft Corporation.
    I'm guessing that may be the company who restored it.
    SOMEONE PLEASE HELP!
    I think the drawing number indicates that it was made by S&S Ltd. of Winnipeg, Canada. The Hamilton decals were likely added by someone after refinishing it.
    I don't recall what aircraft that went on, but it's a fairly common model of display propeller. I'll see if I can dig up information about that model, unless someone else has it right at hand.
      Will you give us the diameter (length)?
        S&S made a number of different props but yours might very well be for a PT-26. You will see some ingredients echoed in your data stamps on the prop hub in this text copied from a page found during a web search:
        The Model 6-440 Ranger engine was the last and largest of four 6-cylinder engines produced by the Ranger Engine Division of Fairchild Aircraft. Designated by the U.S. military as the L-440, this engine was used almost exclusively by Fairchild aircraft. This was an inverted, in-line, 6-cylinder engine.
        Fairchild Aircraft designed and built a series of wood and fabric training airplanes for the US Army Air Corps, Canada, Norway, Brazil, Ecuador and Chile. [Thanks to history furnished on a web site by Kevin Murphy]. In the US, the designator "PT" for "Primary Trainer" was used; in other countries these airplanes were called "Cornells". Kevin's notes continue:
        The final version of the PT-19 series, an enclosed-cockpit version designated the PT-26, was designed for the Royal Canadian Air Force in 1942 with a canopy over the two cockpits. 670 of the PT-26s were provided to the RCAF through Lend-Lease and, in a variation on the Lend-Lease theme, the U.S. Army Air Force ordered 1,057 PT-26s from the Canadian manufacturer, Fleet Aircraft, Ltd. All PT-26s were equipped with the 200 hp Ranger engine.
        A total of 7,742 Cornells were manufactured for the AAF, 4,889 of them PT-19s.
        Specifications (PT-26A):
        Engine: One 200-hp Ranger L-440 six-cylinder inverted inline piston engine
        Weight: Empty 2,022 lbs., Max Takeoff 2,736 lbs.
        Wing Span: 36ft. 0in.
        Length: 27ft. 8.5in.
        Height: 7ft. 7.5in.
        Performance:
        Maximum Speed: 122 mph
        Ceiling: 13,200 ft.
        Range: 400 miles
        Armament: None
        Number Built: 7,742
        Number Still Airworthy: At least 100 (all variants).
