Another request for Sensenich ID
  • Another request for Sensenich ID
    Hello all,
    First let me start off by saying great forum. I have spent a couple hours searching and learning quite a few things about the propeller that has been in the family.
    Searching sensenichs website, the serial that is inscribed is listed as
    "If your Sensenich Wood Propeller has a non-letter prefix or an "A" prefix serial number, your propeller was manufactured between 1932 and 1942"
    Hopefully I can get some help with this. The propeller was one of my grandfathers centerpieces as he was an ex marine and collected war artifacts from all major wars. Unfortunately, he passed before I could learn of its history (it may or not be war related). Here are the identifying marks that I can find,
    Model: S2R272
    Ser: 65859
    HP 200
    RPM 2450
    I appreciate the help. I will post a picture as soon as I can.
    -Andrew
    PS. It has become one of my treasured items, proudly displayed on my wall as it was displayed on my grandfathers
    Thank you for your kind words about the Forum.
    Please recheck the model number. Is it perhaps 82RS72? Sensenich model/design numbers are here: http://www.modernwoodenpropellers.com/sensenich.htm
    What is the diameter (length) of your prop?
      Lamar,
      After taking a closer look, and unmounting the prop and cleaning it a little, I do believe you are correct. This is great news. It indeed is 82rs72. Thank you very much. Using the link you provided and the proper model, I see it belongs to either
      Grumman Widgeon G 44, G44 A
      Grumman OA 14
      Preliminary searches on both aircraft show a flying boat, but most of the pictures on the net show a three blade prop but ill continue my search.
      I just finished taking pictures and will post them up shortly(in the show off your prop section). The prop length is 69.5 inches. The serial is stamped on back of the hub as well. I can never thank you enough. I have tons of pictures of aircraft that has my grandfather next to them. It would be really swell to find one with either of these planes.
      -Andrew
        Pictures are posted
        http://woodenpropeller.com/forum/vie...hp?p=3440#3440
          The prop length (diameter) should be 82 inches. Does your prop have full brass tips? I cannot tell from the pictures. Perhaps it was strike damaged then cut down to make it look better?
