I have an unknown year Fahlin propeller. The decal only says Fahlin and there is no city or state printed on it.
On the hub is what appears to be stamped M B 56 (I could be wrong on this, maybe H B?); and beneath that is 600A.
It is an 8 hole hub with metal which is in 3 separate pieces on the leading edge from about 12" from hub to and around tips. This metal appears to be brass on tips and maybe copper on the inward 2 pieces.
The dimensions are: 95 3/8ths length. (maybe 95 1/4 just expanded from age?) It is 5 layers thick measuring 4" total at hub. Dia. of bolt holes is 3/8ths". Center to center on holes is 5 1/4". Center bore is 2 11/16ths". and the crush plate measures 6" across.
I hope that I've measured correctly per the Hub Dimensions Chart on this site and that I've described this correctly. I hope to find out the approximate year this propeller was made? Last use was supposed to have been on a Ranger engine/unknown aircraft though. Thanks, Sharon
