If I did the conversion correctly 68 cm is the equivalent of 26 inches. If I did that correctly it's most definitely not an airplane or drone prop. Perhaps a prop for an auxiliary generator. Can you post pictures?
I did not receive the emailed pictures. I did check that the email button is working as expected and it does. Did your email perhaps 'bounce' for some reason?
It's so short because the ends of the blades have been cut off, perhaps due to some sort of damage. With only four bolt holes it might be a generator prop I suppose. The markings mean nothing to me. Perhaps someone else can decipher them.
My Dad flew cropdusters (Stearmans) from the mid 50's until the early 80's. I have seen props about this size that were used to turn spray pumps or as part of a "pelleting wing". Rusty
