Sensenich 8 Bolt 98.5" long Serial #AF-4354381
  • Sensenich 8 Bolt 98.5" long Serial #AF-4354381
    Hello all, I have this propeller and I am am interested learn more - like manufacturing date, what planes it could have been used on, an estimated value range.
    The following information was available on the side and I uploaded 4 pictures. I would be grateful for any insight anyone could provide. Thank you, My Best, Mike
    Sensenisch
    Part#: 42K19593
    Serial #AF4354381
    R-?? 5 Engine
    220HP 2100RPM
    98.5" tip-to-tip
    6" Wide
    Inner mount circle 3 3/4"
    This gallery has 4 photos.
    The 42 in 42K..... is the year of the military contract used to produce them. You need to go to this page (and find the corresponding civilian model number (90LA -76), which leads you to the listing on this page (https://www.woodenpropeller.com/Military%20numbers.html) (https://www.woodenpropeller.com/MWPSensenich.html) which list the aircraft as Boeing PT17 with the Continental R670 engine.
    The prop was obviously cut in half for transport then reassembled. It likely had Sensenich decals that have been removed.
    wooden propellers, wood propellers, wooden props, wood props
      Wow...so very helpful. I very much appreciate you and your time taken to respond. I will check the provided links to try to learn. Yes, sadly no Sensenich stickers and I am sure the fact that it was cut in half impairs desirability a bit and certainly impacts value. its still quite cool nonetheless. You are the best......thank you. Take Care, Mike
        To anyone interested, I will be selling soon. If interested please call me Mike Mallon @ 708 846-1953. If I don't hear from anyone soon I will likely run via an eBay auction.
