You would need the numbers stamped on or around the hub to identify it. There are thousands of different propellers, most looking the same as others, but often design numbers can narrow that down, sometimes to one make and model aircraft.
yeah I haven't found an numbers on the prop at all, my initial inclination was it was from some sort of float plane since it was found at the bottom of the bay in Ocean City, MD. But I guess it probably could have been dumped as well.
