Hi there,
I‘m trying to identify a wooden propeller from an aircraft that crashed about a 100 years ago in my grandparent‘s backyard.
To its dimensions
Length: 188 cm
Center bore diameter: 55 mm
Bolt hole circle: 115 mm
Diameter of hub: 144 mm
Number of bolt holes: 6
Bolt hole diameter: 10 to 11 mm
Hub thickness: 78 mm
The wood should be walnut.
And the plane crashed in the west of Germany.
Unfortunately there are absolutely no markings or any other signs on it.
Any support is welcome.
Thanks ever so much
Jan
To its dimensions
Length: 188 cm
Thanks ever so much
Jan
