Hi all and greetings from Berlin, Germany.
I actually re-found around half of a propeller, we found around 20 years ago in the garage of my grandfather. It belonged to his father, who worked as a director for Junkers in the 30s and first half of 40s, up to the day, when the sovjets decided that he should change his profession. My grandfather told me, that the prop was cut, to trade some food in the times after war with a carpenter.
It would be great, if you could help me to identify this nearly only piece of my family's history.
To the prop:
-It seems to be 8 layers of wood, the thinner once are darkened
- the stamps say: N 7975 ; D 214 ; 60 PS ; St. & C ; Circeled "J"
- 1/2 length (from the middle) is: 40,5 inch (103cm), so it should have been 81 inch (206 cm) when it was complete, the hub is 4,3 inch (11cm) thick
- weired Detail: there is a tiny hole, with a piece of metal in it, too small for a regular projectile
Thanks for reading, your time and maybe help.
Best wishes, Sebastian
To the prop:
