Hi all,
I have a Sensenich prop for a PT-22 that is not airworthy and was left in the elements when I found it. I'm doing a restoration for display purposes and I'm to the point of applying new, old fashion style SB waterslide decals that I recently ordered directly from Sensenich.
When I wetted the first decal (in room temp distilled water) it began to curl as I'm used to. But then it began to crack all over. This happened even without my trying to remove it from the paper.
I should also mention there were no instructions included. I have read that some decals require a clear coat going on before use if they're cheaply made, but these were $35/set!
I have contacted Sensenich and hope they can offer some assistance. Just thought it worth asking here, as well. Thanks in advance for any advice.
