Hello
Although this has been said many times before I have to repeat previous post and congratulate you on a wonderful site.
Having brought a prop I am eager to learn about its past.
I have attached a couple of photos below which will hopefully be of help.
In addition I can confirm the following information
Length: 9,5”
Blades are 113/8 inches across the chord (the widest part)
Outside diameter of the hub is 12 inches
Centre hole of 33/8 inches
10 bolt holes each 9/16ths of an inch in diameter
The blades have brass leading edges which are riveted
There are some reference numbers on the hub which have been varnished over and are difficult to read and photograph. As far as I can tell these are some of the numbers and letters which appear.
JUL ?? ?????
?? DT?? 2370 STIGN 1990
JO?3K NR 22
Thanking you in advance for any help you can provide.
Length: 9,5”
JUL ?? ?????
JO?3K NR 22
