Fiat prop.
  • Fiat prop.
    Hi this is Semih a new member from Bergamo Italy. As I was trying to identify the wooden prop I received as a present yesterday, I came across with woodenpropeller web site.
    It is made by FIAT as I understand and dated 10-June-1927. The rest of the details of the prop (each side of the hub) as are follows:
    Frist Side:
    A 300 / 4 - FIAT
    DIAM 2.85
    PAS - 2,00
    DIS - 85 - 4000
    Second Side:
    N - 2871
    007614
    COLLAUDO (Means tested on the following date)
    10 - 6 - 1927
    Any info is most appreciated.
    Regards
    I have no idea what that one is from.
    If you find a list of Italian propellers (manufacturers and drawing numbers), please let us know as we have nothing at this point.
      Thanks Dave,
      So far the only info I found is that it most likely belongs to an Italian aircraft company called CAPRONI, but there are quite a few variants.
      If I find anything it will be a pleasure to share with you.
      Semih
