I have this wood propeller and hub and would like information as to who manufactured it and what plane and motor would have used it. The propeller is 7' 6" long, has 8 bolt holes, appears to be made of walnut, appears to have 7 laminantes, hub thickness is 4", bolt pattern is 5 1/4", has DES 61C and 6089 92 stamped into the wood. There are no other numbers on the prop or hub that I can find. This prop has been restored at some time and there are no decals remaining and no information under the metal hub. Any information would be appreciated as I would like to sell the propeller and hub. Thank you Mel
Need help identifying wooden propeller
I have a wooden propeller I would like to sell but do not know the manufacturer or the motor or aircraft it may have been used on. The propeller has DES61C & 6089 92 stamped in the wood. The propeller is 7'6" long, the hub is 4" thick, appears to be 7 laminates, the bolt patter is 5 1/4", appears to be made of walnut, no decals or any other markings on the metal hub or under the metal hub. Any information would be helpful. Thank you, Mel
I have a wooden propeller I would like to sell but do not know the manufacturer or the motor or aircraft it may have been used on. The propeller has DES610 & 6089 92 stamped in the wood. The propeller is 7'6" long, the hub is 4" thick, appears to be 7 laminates, the bolt patter is 5 1/4", appears to be made of walnut, no decals or any other markings on the metal hub or under the metal hub. Any information would be helpful. Thank you, Mel
Propeller for sale!
Greetings Mel, I'm interested in your propeller and hub. I can be reached at msprior01@gmail.com
Thanks, Scott
P.S. Are you located in Homasassa springs?
