I am looking for more information on a wooden B-M prop that have had for many years - probably since the late 60's. I checked the Wooden Propeller site under B-M and it does not list this prop. Would like to know what it was used for, maybe what it's worth. It is no longer airworthy since it has a sliver missing at one of the trailing edges and someone before I got it drilled a hole in the center of ea blade probably for mounting it to a wall.
Here are the details:
Banks - Maxwell Propeller Co, FW Tex
Length: 60"
Laminated wood with riveted brass leading edge covers
Model: 560-34 (Stamped on side of hub and on back of hub)
Ser No: 2375 (Stamped on side of hub and on back of hub)
# Bolt holes: 6
Please let me know if I need to post more info.
Thank you
Length: 60"
# Bolt holes: 6
Thank you
