this is a modern wooden propeller, the numbers on it say as follows
FAHLIN D-512
NO 3083 HP 90
RPM 2025
EM 2-17
problems reading R in RPM
the "25" in 2025
Not sure if the last line is an E or B for the first letter
The Back side of the prop reads JT 405, below that reads 512 -
The propeller has 8 holes around the center hole and has brass plating on wings of propeller tips continues plating down thick side of prop wing ending around middle of prop wing. I know that may be diffucult to understand my info on the brass plating but hopefully it will help.
Mainly wanted any information that anyone may have on this propeller, if anyone has or knows of what the bolts looked like that mounted this prop. This is my Great grandfathers propeller and i am going to mount it up on my wall. I want the prop to look like it did at the front of the aircraft with the certian bolts and washers. any info on where i could also purchase the bolts and necessities that i will need would be greatly appreciated,
FAHLIN D-512
NO 3083 HP 90
RPM 2025
EM 2-17
the "25" in 2025
