I have a Hartzell wooden propeller with the following data:
ATC No 722
HP 65
Design 824 A\45(72)
SR No 19847
RPM 2350
Friends have told me the prop was designed to generate 65 Horsepower at a sustained cruising speed of 2350 RPM's. The 2-blade prop, in fact, is 72 inches long and, apparently, began life with a 45 degree 'bite' to the blades.
I do not know what the following data mean: ATC 722 - apparently it is not a valid Air Type Certificate - Design 824 A - what engine? - and, finally,
SR No 19847 - since Hartzell does not keep records by serial number.
Can anyone out there help me out? Any idea of date of manufacture, for what engine, and anything else? Is my current understanding of the data correct?
Thanks for any help.
ATC No 722
HP 65
Design 824 A\45(72)
SR No 19847
RPM 2350
