I Think I have the identical propeller that is on the top of Modern Propeller web page.
I started out on the antique sight because I zoned in on 8 hole bolt patterns as being only antique. Now I know better, but my initial research led me to believe it is a Le Rhone because of the hub dimensions.
Hub Bore (B) 2.375
Bolt whole circle (C) 4.75
Hub diameter (D) 5.75
Number of bolts 8
Hub thickness (G) 4.25
It is about 6’6” in length
There is a number 2 over 10728 on the back stamped into the wood by the hub.
So since it is a modern propeller like the one on your web page what is it?
I am interested to find out anything I can about this prop. Painted as it is, it’s not very attractive and I much prefer the lacquered wood look but I don’t won’t to destroy its value. I would like to find out what plain it used to pull and what value it has if any other than as a decoration.
I look forward to hearing from you
Sincerely
Michael Hodgson
Hub Bore (B) 2.375
Number of bolts 8
Sincerely
Michael Hodgson
