Greetings everyone! I have a nice vintage wood hartzell propeller that I'm trying to find some info about (approximate age and aircraft type). It is 108" X 4 1/4" thick at hub. "toothpick" shape with no cloth or medal cladding. 6 bolt hub with metal mounting hub attached (threaded on engine side and slotted on front). Markings are- DESIGN 830/A/46 (10 SR.NO.282?? HARTZELL PIQUA, OHIO. Decals are Hartzell (no liberty or walnut). I did not see the design 830 in your Hartzell reference list and was wondering if you could help me out. Thanks much, Scott
It was built under type certificate #722 and used on a 65 HP engine.
The Type Certificate expired December 31, 1954.
Another listing I have shows it as designed for a Luscombe 8A with a Continental A65 engine, but it shows it as only 76" in length, so I have no idea why that discrepancy exists. The pitch is listed at 46", so that may be the significance of the A/46 number.
You're sure the propeller is 9 feet long? That's unusual for a 6 bolt pattern hub.
