Firstly - Hi, & what a fantastic site/forum.
I have a serious engineering background, but I never once imagined that this would be such an involved field!
I've just removed from a wall (Due to decorating.) 2 blade prop for which couriosity's gotten the better of me. I know nothing more than I was told when I received it - Supposedly it's meant to be around WWI (Hence posting here, apologies if I'm wrong.).
There are no manufacturers marks or decals on it anywhere, but the 8 bolt hub has the following marks:
DWG. Z5./01./2./B
D5.P4.78
86459
The blades are Copper(?) edged and each blade is marked "1" & "2" on its inner rear face.
I've had a good rummage around the forum/site but only found how to identify the diameter & pitch (Much more than I knew!). I can pop out to the barn & get a photo, or 2, if it helps.
It will be going back on the wall eventually, but I'd like to have a plaque engraved with a bit of relavent info, if possible.
Any ideas?
Thanks in advance.
Glenn.
DWG. Z5./01./2./B
D5.P4.78
86459
Any ideas?
Thanks in advance.
Glenn.
