This last weekend I was shown what appears to be a vintage aircraft propeller. The person who holds it got it from another chap who claims it is a propeller off 'a World War 1 Avro' - presumably a 504.
I took some measurements and photographs of this item, which is currently mounted on a wall. It was apparently found underwater, so all markings have been erased by the process of time - probably by sand abrasion. The measurements (I only had a metric tape with me) are
Overall length tip to tip 2730mm
Diameter of hub 200mm
Thickness of hub 145mm
Width of blade at widest point 230mm
There are 8 bolts in the hub, and 6 laminations of timber in the blades.
The item was said to be found at Tauranga Bay, in New Zealand's Northland area - see map below. This could possibly make sense for a 504K relic, as there are two potential sources:
- The New Zealand Flying School (Walsh Brothers & Dexter) operated 504L seaplanes in the Northland area in the time period 1920 - 1924.
- Les Brake, an itinerant joyriding pilot operated an ex-NZPAF 504K off beaches in Northland 1931 - 1933.
Any identification/feedback on the above welcome.
