Help! I am trying to figure out what era and aircraft my propeller is from.
Description:
-Falcon decals
-98" tip to tip
-copper on ends of tips and leading edges
-anchors and "US" stamp on each blade
-4" thick hub
-69mm interior hub diameter
-8 bolt holes
-6" hub diameter
-appears to be oak
-5 1/2" bolt hole cirle
The following is what and how the blades are stamped:
2.
8.2.. X 5. (periods are stamped at top of numbers)
S.E. /-/ 100 /-/ 128 (backslash are really straight up)
Other blade:
1286.
10001.A.
T.M.
Thanks for any info. in advance,
Sam
Description:
-Falcon decals
-98" tip to tip
-4" thick hub
-8 bolt holes
-6" hub diameter
-appears to be oak
2.
Other blade:
1286.
10001.A.
T.M.
Sam
