Gentlemen:
Here are the specs and the url at bottom of post should provide some pictures of this prop; the four bolts seem to be the big stumbling block. Any help to id this would be appreciated.
Shaft hole center to blade tip 52 in.
Overall length 104 in.
Hub Outside Diameter 13 in.
Shaft Inside Diameter 3.25 in.
Edge bullet nick 22" from center
Two mid-prop nicks 30.5" from center
Hub max thickness 4.875 in
Laminations mahogany 6
Hub mounting bolt holes 4 holes; 0.5" dia.
Bolt hole circle 8 in.
S/N stamped at outside of hub cut 226b
Outside hub flange depth 0.75"
Rear hub outer flange depth 1.25"
Rear hub inner flange depth 0.625"
Stencilled on left blade outside face:
"THIS PROPELLER NOT FIT
FOR FURTHER SERVICE
CONDEMNED DATE 5.11.19"
[Date numbers are stamped into wood]
http://picasaweb.google.com/lincoln1...ey=KSlfGt7ftp8
FOR FURTHER SERVICE
