Hello all,
I've been lucky enough to inherit two old propellers recently; they were my great grandfathers who served in the Royal Naval Air Service in the first World War (amalgamated into the RAF in 191
, and I was always told that they were from seaplanes (makes sense to me). I have always liked them, but only now have I had a really good look at them, and realised that I might be able to find out a bit more about them from the markings that I've found on the hubs. Needless to say, I was very pleased to find this discussion forum, and would be very grateful if anyone might be able to help me with this. Anything at all that you can say about them, would be helpful!
Ok, so onto the details. Neither is in perfect condition, but frankly, I consider myself very lucky to have them at all...
Propeller 1: Two bladed, all wood, Measures 9 feet 8 inches long. Has decals on each blade with an eagle above some hangars, and the logo "The Brush Electrical Engineering Co. Ltd, Loughborough, England. Falcon Works."
On the front of the hub also is engraved "The Brush Elec. Eng. Co. Ltd. Loughborough. P.2.38, D.2.9, No. 189."
On the side of the hub is "80 HP WOL. REN." and on the back is a stamp "ADP" in a circle. There are 8 bolt holes in the hub, hub diameter is 8 inches across, inner diameter is 2 3/4 inches.
Hopefully the photos will work:
Propeller 2: I was told that this one came from a crashed plane, and has been cut down, so it's only around 6 feet long now. Its a bigger prop though (wider blades and hub - hub diamter is 10 inches), but has been modified to take a ships clock... A shame for the purists, but should be
interesting to research the ship. It still has half of ships name and its home-port (Southampton) visible. The rest has been rubbed off by 90 + years of winding. Even better though, it runs beautifully!
What is still visible on the front of the hub is that same stamp "ADP" in a circle, and the code 3 S93. On the side of the hub is engraved: 10 FT - 9 INS DIA, 67.58 PITCH, 225HP SUNBEAM. Oh and there are 10 bolt holes in it.
(Anyone know anything about clocks?)
I would be really interested in any help that anyone can give me with these. I have recently tracked down my great-grandad's service record, and even found an old picture of him in uniform, so you can imagine how special these propellers are to me - a real link with the past.
If you've read all this, thanks for your interest...
Cheers
Daegan.
Cheers
Daegan.
