Hi!
I am new to this forum, and I am investigating the following:
A colleague of mine brought this propeller to work today.
He got it from his old ant that found it in the attic...
It is obvious from some kind of wind driven generator, but for what aircraft.
We are certain that it's orgin is an aircraft once operated by the Norwegian Air Force or (if it is WWII) possibly some German type.
It is produced by "Helice Levasseur" and measures 60 cm in diameter (tip to tip).
The blades are wooden and the hub has the following stamped into it:
"6309"
"MAP"
"C" (inside a ring)
"P4 PT" inside a hexagon
Both blades are individualy adjustable with a scale numbered from 0-33 on each blade root.
Both blades got a table that probably is a guide to adjusting the pitch for
best angle/flying speed) (see pictures)
So, over to the experts out there.
If anyone could help me with a few clues to how old it is or even better what types of aircraft might have used this type of wind generator, I would be very happy.
E.
(Norway)
edit: pictures linked
"6309"
"MAP"
"C" (inside a ring)
E.
(Norway)
