Dear all,
I have recently purchased a wooden Propeller from an Antique store in London. This is an Eclair Propeller "Helice Eclair" with the following Markings:
Helice Eclair Paris (on the blade)
(on one side of the hub)
SPA
HS 150
n 1
Nf
(on the other side)
Serie No 6
No 366
HIS ---faded--- 150HP
It has 8 holes through the Hub
it is 240cm long and 150 wide at the hub
I would appreciate if anyone could provide any information regarding this propeller. I have found the story of the Helice Eclair but i am specifically looking to know what aircraft was this mounted on. I have found that the SPAD VII use this prop, and the marking "SPA" would probably confirmed it. Also there are a lot of inspection stamps which probably mean it has been used on several occasion. Checking the tip of the prop there seem to have been repaired with wood pin. I am wondering if this could have been flown and then damaged, repaired and flown again.
This propeller has definitely been refurbished so all the original paint is gone but I can see some residue of the red/burgundy paint in some area and inside the indentation and markings.
Thanks for your help on any information regarding this propeller.
Xavier
SPA
HS 150
n 1
Nf
(on the other side)
Serie No 6
No 366
Xavier
