Hello everyone, Thank you for reading my post.
I have zero experience of propellers or aviation things generally so I really do appreciate your help.
The propeller I have has the following details -
Serial Number - 1 3060/60576/20
Length - 6'
Blade width at tip - 3"
Blade width at bearing hub - 4 3/8"
Number of bolts - 4
Bearing hub width - 3 6/8"
Bearing inner diameters - 1/2" and 6/8"
I wonder about this propeller, as from what I have seen, with only four hub bolts, that it perhaps wouldn't be robust enough for an airplane/airship or airboat, that perhaps it had an industrial application instead??
The hub bolt nuts have 3 alloy nuts with fibre locking, and one nut in mild steel with a stainless (??) lock washer on top. I think the fact they were changed/maintained suggest a lot of use perhaps, and could this mix of bolts fit with the advent of fibre-locking bolts in 1931??, does the '20' at the end of the serial number give us a date of manufacture??
It does look like has some age to it and I would love to hear some opinions about it (if anyone has any!!)
Many Thanks,
Brian
Length - 6'
Number of bolts - 4
Many Thanks,
Brian
