Hello.
Just came across this half wooden propeller.
No markings found except for a rectangular stamp on the blade with text in it.
I can’t read it.
Lenght is full propeller 250cm
Bore diameter 60mm
Edge bordered with sheet metal.
Hub diameter is 190mm
Bolt hole circle is 140mm 8 bolt holes diameter 10mm
Can someone identify this half prop?
Greetings,
Geert
I can’t read it.
Bore diameter 60mm
Greetings,
Geert
