The prop is in good condition and the owner would like to sell it. He doesn't speak English, so I posted the pictures here. Considering the length of the prop, it is surprising that it has only six bolt holes. It is possible that the prop was never used on an aircraft and the bolts were drilled later for whatever reason?
There is a French made Chauvière with quite the same dimensions, the serial 2410-1, with 270 cm diameter and 150 cm pitch. It was used for test flights of the Rumpler fitted with a 110 HP Benz.
Here a pic of a Benz Bz II 100 HP with clearly a 6 bolts propeller: https://www.flickr.com/photos/andybailey/25768441824
So, the one you show, (which is very attractive!), seems "normal".
With reference to the post above, early German aero-engines, c1912-c1914, had hubs with six bolts. Within a year the development of the Mercedes engine to 160ps led to the use of eight bolt-holes.
I have recorded six early prop-makers who made props for the 6 cylinder 100ps Mercedes engines. Incidentally, the power output of this Mercedes engine increased quickly from the 4 Zylinder 70ps engine to the 6 Zylinder 100ps, 110ps, 120ps and 160ps engines.
Known makers of propellers for early aircraft with 100ps engines are listed below, with the aircraft type (where known) written here in red, showing the data as stamped on the prop hub.
Anker Walther
Axial Pfalz E.V (hub marked 100ps and later over stamped to 110ps)
Behrend und Ruggerbrecht
Fliegel
Garuda LVG B.III
Germania Alb B.2 masch
Halberstadt
Heine Rumpler Taube, B.1 Ed: probably an Alb B.1
Integral Alb Doppeldecker Ed: Alb B.1 or Alb B.2
Imperial
Markgraf und Tau
Rahtjen
Reschke Rumpler Taube
Saturn
Schwarz
