This propeller has a decal which reads Matthew Bros Mfg Co, Milwakee Wis. USA. around the edge and Hamilton in center.
Stamped on prop is Matthew Bros MFG Co. , N-12172, 8" 4", SE 5090, HS-2. Measurements are as follows:
center bore diameter- 3 3/16"
Bolt hole circle-8"
diameter of hub- 10"
number of bolts-8
bolt hole diameter -1/2"
hub diameter-3 5/8"
Think it might have been off a M F Boat with a Curtiss OXX 6 engine???
Any ideas?
Bolt hole circle-8"
number of bolts-8
hub diameter-3 5/8"
Any ideas?
