Looking for assistance/guidance identifying serial number D5000 16263 or anchor with US insignia. Thank you. Propeller Purportedly from a Jenny plane, 1920s.
Can anyone explain the insignia on this Jenny propeller
The first image may represent a Paragon propeller. (The "P" was assigned to the American Propeller Manufacturing Company, which produced Paragon props.)
The numbers below it indicate the diameter and pitch of the prop. So it should be 8 feet in length and (in a mathematical sense only) should move forward 5 feet 3 inches per revolution.
I'm just a bit skeptical that it's definitely from a Jenny because of the U.S. Navy stamping, but it is the correct size for one.
I don't know about the bottom photo numbers. Can you post a picture of the whole prop?
It's hard to tell from that angle, but you need to measure the distance from the center of one bolt hole to the center of the bolt hole furthest away from it. That's the bolt circle diameter, and it can eliminate one or more engine types from the possibilities.
You still need to find the bolt hole circle diameter. It's a critical diameter since it can rule out certain engines. I'm just guessing though that it fits either an OX5 engine or a Hall-Scott A2A engine, but those will have different hubs.
Here is the requested measurement (I hope!):
5 1/4 inches based on your diagram at http://woodenpropeller.com/forumvB/a...1&d=1559913957
Thank you for being so patient with me!
Heidi
So I think it's highly probable that it was made for a Curtiss OX5 engine. The problem comes with the fact that that engine was used on a whole range of different aircraft, so while the JN4 might have been one of them, there's usually no way to establish that fact to a buyer, for instance.
