I’ve just required a nice wooden prop with following info on the hub.
CR1 HS 300HP
D 2480
P197
LP220
DIS 520
On the other side a number and 26 8
The edges are sheet metal.
I’ve done some research and found the following
In Belgium they did test with the Fiat CR1 in 1925 and 1926
One plane crashed.
They have rejected the planes.
So only 2 where used.
Perhaps the propeller came from the one that’s not crashed.
Only Italy and Latvia used this airplane.
Propeller was found in Flanders Belgium so......
Anyone with more info?
Greetings!
CR1 HS 300HP
D 2480
P197
LP220
DIS 520
One plane crashed.
Greetings!
