Hi....New forum member and new wooden prop owner.
I have a wooden airplane prop that i'm trying to research. Would like to know what type of plane it may have been from and its year . Ill list the info that is marked on the prop itself.
On one side of the hub it says ," Glenn L. Martin Co."
On the opposite side of the hub it has several lines...
115 x 60
M.O.1. AIRPLANE
SR. NO. 1942
OAK
There is a metal material riveted along the tip and just the edge of each blade to just before the hub.
I measured the blade tip to tip and its 115 inches so that explained the "115", i used my bathroom scale and weight it and its close to 60 lbs so i'm assuming the 60 is a wieght of the prop.
Any body know what i've come across here??
Thanks for any info.......Chuck
115 x 60
M.O.1. AIRPLANE
SR. NO. 1942
OAK
