Ventured into the attic of my folks old home settling the estate. Known to all the kids (myself, one brother, two sisters) a propeller my father acquired from Teterboro Airport, NJ in the late 20's and bicycled home to Lincoln Park NJ. He always felt getting it home was a greater feat than acquiring it. From memory (my brothers) was on a trainer plane. I did a quick research and am of the thought a French training plane WWI. I do want to determine more of its history. On either side of the propeller itself imprinted into the wood is "Helice Paris Eclair". On the spindle portion of the propeller has "Rh 190hp" as well as "Are". On the opposite side of the spindle portion has an "8" upper left "DG 5" a little below. Next to the DG5 are 3 squares offset from each other. Just to the right of the squares and a little lower is an "8". Going to the lower portion......lower left has "SERIE " "W" (W with a question mark because not completely clear). Then next to it (below the center hole) either 180 or 130 or (my suspicion as a confirmation to hp) 190. Then to the right of that number (imprinted a little higher) No.415. Now that I joined the club I will get some additional information. It does have the large center hole with an 8 "lug" pattern.
Any information about its origin appreciated as well as any other clues to look for. I will be getting measurements and scrutinize the propeller more diligently and post as I get them. Thanks in advance.
gchuba
gchuba
